This procedure only applies to the VSP 7400 Series.
Enable Distributed Virtual Routing (DvR) globally on the node.
Perform this procedure to view the DvR Multi-area SPB backbone entries that the system learns from all Controllers in all DvR domains.
You can view the backbone entries only on a DvR Controller. Viewing backbone entries does not apply to a DvR Leaf node.
- Select DVR.
- Select the MultiArea Backbone Entries tab.
- Optional: Select the Filter button to filter the rows on basis of specific criteria.
MultiArea Backbone Entries Field Descriptions
Use the data in the following table to use the MultiArea Backbone Entries tab.
Name |
Description |
IpAddrType |
Specifies the address type of the DvR backbone host (IPv4 remote ARP). |
IpAddr |
Specifies the IPv4 address of the DvR backbone host. |
L3Isid |
Specifies the Layer 3 I-SID of the DvR backbone host. |
DomainId |
Specifies the domain ID of the DvR backbone host. |
EcmpIndex |
Specifies the ECMP index of the DvR backbone host. |
HostMacAddr |
Specifies the MAC address of DvR backbone host. |
L2Isid |
Specifies the Layer 2 I-SID of the DvR backbone host. |
AdvControllerName |
Specifies the host name of the advertising Controller. |
AdvController |
Specifies the host MAC address of the advertising Controller. |
NextHopName |
Specifies the host name of the next hop Backbone host in the DvR route. |
NextHopMac |
Specifies the MAC address of the next hop Backbone host in the DvR route. |
Area |
Specifies the type of area as home or remote. |
